Interior Lighting - Page 2 - SailNet Community
post #11 of 30 Old 06-24-2008
A lot of the replacement LED bulbs leave a lot to be desired in terms of light output and color. YMMV.
Originally Posted by merttan View Post
You can buy the regular fixture and change the light bulbs with led bulbs... I find it rather inexpensive instead of buying the whole setup... Another positive to this is you can change the LED light bulb if you need to...
sailingdog is offline
post #12 of 30 Old 06-24-2008
Alpenglow marine lights
Check out
Home
I have seen them in operation and like them. Seems a good company.
gtod25 is offline
post #13 of 30 Old 06-24-2008
merttan's Avatar
Change the bulbs with LED bulbs, bleach the plastic covers, and enjoy the season... Off season you can deal with the whole changing the fixture project when the stuff is cheaper...
" I refuse to engage in an intellectual battle with an unarmed man!"
Materialism: Buying the things we don't need, with money we don't have, to impress people who don't matter.
merttan is offline
post #14 of 30 Old 06-24-2008
merttan's Avatar
Originally Posted by gtod25 View Post
Check out
Home
If you are handy, you can make those box fixtures in your garage... A simple teak box with some plastic light cover... Then simple cable soldering...
merttan is offline
post #15 of 30 Old 06-24-2008
Freesail99's Avatar
A simple teak cost could end up costing you $40.00 or more, just for the wood alone.
S/V Scheherazade
Freesail99 is offline
post #16 of 30 Old 06-24-2008
Merttan-
You could make up a box light--but Alpenglow are one of the few outfits that make lights which don't create radio interference. You won't be able to buy ballasts and electronics of the same quality at your local lighting or hardware store. That's what made their reputation.
hellosailor is offline
post #17 of 30 Old 06-24-2008
I didn't know that led bulbs were polarity sensitive until I tried to replace the incandecent ones which are not. My fixtures wires need to be reversed to use the new bulbs. bummer.
bushrat is offline
post #18 of 30 Old 06-24-2008
It depends on the type of bulb, but most can be reversed. This applies to the double contact bayonet type, the halogen replacement type and the festoon type bulbs.
post #19 of 30 Old 06-24-2008
It's worth checking first. Mine are the single contact 1141 auto bulbs. My replacement led ones don't work without a polarity reversal. I was thinking of just pulling the breaker and making the switch there. I have a cabin light dedicated breaker. Should be an easy mod. I was hoping for plug and go...rats!
bushrat is offline
post #20 of 30 Old 06-24-2008
Just remember, that reverses the polarity for every light fixture....which you may not want to do.
