06-20-2008
This is why I upgraded to TackTick instruments last year.  No more wiring issues.
Originally Posted by JimsCAL
Could also be a problem in the cable running from the top of the mast to the readout. I had/have a very similar problem with my Standard/WM wind direction display. They told me to remove the transducer from the top of the mast and plug it in directly to the display (they have same connectors). Everything works great when plugged in directly so the problem is in the cable. So that's on the list to be changed next time the mast comes out.
