Old 06-20-2008
75R20 is on a distinguished road
Question Shore Power for a small boat?
Is there any reason that I can't do this? I want to add a Marinco charging plug to my trailer boat (20foot) and wire the charger and add a 110 volt outlet for a heater when at home or a laptop or something small while staying in a marina when cruising. The charger is an .8 amp output to maintain my AGM battery and I would add a breaker for the second circuit. Is there something I'm missing? the boat is fiberglass.
Thanks
Kary
#49080
Old 06-20-2008
EO32's Avatar
EO32 is on a distinguished road
I'd just make sure you wire the AC green ground to the boat ground. If you don't have a boat ground then just wire it to the outlet ground.
Also you may want to put in a GFI outlet to protect yourself.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 06-20-2008
Kary-
Sailor's Solutions has a good small AC main panel that should work for you. It has five breakers on it... four effective, since the top two are ganged for the AC input and one handles the neutral, one the hot line. The two of the other breakers are 15A, and the third is user choice of 15A or 30A.
It's the same one I'm using for the Shorepower AC panel on my boat.
I would go up to a 6-10 amp marine three-stage battery charger, since it will re-charge your battery rather than just "maintain" it.
I would also recommend you go with GFCI outlets, since they'll help protect you from getting electrocuted.
Parts required:
A more basic AC panel would be about $80, the one shown above is $160.
The wire is about $1.20 per foot for 10 AWG triplex marine AC wire—figure 15'—$18.
A 40' 30 amp shore power cord is $49.
The shore power inlet is $45.
A GFCI-equipped outlet and box is $10.
A tube of marine sealant, like 3M 4200, is $11.
BTW, the reason the main AC breaker on the panel is a double breaker is that the breaker cuts both the HOT and NEUTRAL lines. If you didn't do that, and had a reverse polarity situation, you could still get electrocuted.
Thanks
Kary
#49080
Old 06-21-2008
Thanks for the insight
I hadn't quite got to the GFI part but I'll definitely go with one of those. There's not enough room on the bulkhead for a second panel, but I will try to incorporate the 110 breaker that does both Line and neutral into the panel I have.
Kary
#49080
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
Life in the fast lane, well for one day at least... Lancer28 Learning to Sail 8 11-27-2007 10:36 PM
Small Boat Cruising David Schaefer Cruising Articles 0 06-09-2004 08:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 07:00 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
