06-20-2008
It might help if you said what kind of winch you were trying to mount. Also, mounting plates or bases can be made up out of Teak, thickened epoxy, fiberglass, aluminum, etc.
The reason most winches are probably mounted across from each other is that winches need to be a good working height. There's only a fairly limited range of heights a winch will be easily operable at.
