Im a complete IDIOT! - Page 5 - SailNet Community
post #41 of 55 Old 06-25-2008
Freesail99's Avatar
If you do take this boat out, please wear a pfd. I personally would ripe it out. I ripped out a keel repair done using mat and epoxy. I replaced it with 4 layers of 6.5 oz e cloth wetting it out fully with epoxy. I also used 12 inch wide 9 oz fiberglass "tape". I then put 4 layers of epoxy over the entire bottom of the hull.
S/V Scheherazade
Freesail99 is offline
post #42 of 55 Old 06-25-2008
I'd agree with Free... wear a PFD and file a float plan before going out in it. I would highly recommend ripping out the CSM, since the tensile strength of the sizing is relatively low, and that is effectively the weakest link in the repairs you've made, since the epoxy is bonding to the sizing—not the glass fibers within the sizing.
sailingdog is offline
post #43 of 55 Old 06-25-2008 Thread Starter
Look, Im not crazy! Ill wear a life jacket.
Ive just been smacking away at that sanded down filler with a heavy screw driver. Feels solid as a rock.
Maybe im just choosing not to hear bad news.
Ive got to think about this.
Ill have another look at the csm when i turn the boat back over.
Might not be to hard to grind that back.
thanks for the advice
stu9000 is offline
post #44 of 55 Old 06-25-2008
How much force do you generate swinging even a heavy screwdriver. Compare that to the force that is applied when the boat comes down off a wave with two people in it.... one is significantly greater than the other, don't you agree??
post #45 of 55 Old 06-25-2008
blue collar cruiser
soulesailor's Avatar
It sucks so bad to take apart work you've done I totally feel for you. If you do end up taking the layers off you can really save yourself some time by using a grinder instead of a belt sander. 40 grit and 10,000 rpm makes quick work of taking down glass. Good luck.
who is staring at the sea is already sailing a little
soulesailor is offline
post #46 of 55 Old 06-25-2008
'72 Pearson 36
SVDistantStar's Avatar
Send a message via AIM to SVDistantStar
Okay, so this explains why i had one hell of a time making CSM take the shape of the rail on my rowing dink. I did make it work, but it was tough. I covered that repair with fibreglass cloth and epoxy and it seems solid. I also did a repair on the bottom of the bow using a layer of CSM and cloth. Its also solid, i think.
1972 Pearson 36 S.V. Distant Star
SVDistantStar is offline
post #47 of 55 Old 06-26-2008 Thread Starter
Its not chemically bonded but it is structurally bonded.
All that hard epoxy permeating the matt and well keyed to the wood.
Ive ordered some Biaxial Tape 150 mm 450gsm tape to add another layer.
stu9000 is offline
post #48 of 55 Old 06-26-2008
Freesail99's Avatar
Epoxy CAN NOT structurally bond to mat, and that is the point, we been trying to make. All you have is a surface coating of epoxy over the mat.
S/V Scheherazade
post #49 of 55 Old 06-26-2008
arbarnhart's Avatar
I have zero credibility in this thread since I thought mat and epoxy was fine, but I think I understand what stu means. When I used them together, I did fill the void with something hard. I did get the mat wet with epoxy; there weren't bubbles or soft spots. But according to the info I read the other day, the mat was supposed to unbind and have the fibers mix so that they would bond like one unit and I guess that didn't happen.
But stu, think about this (and try it if you're really bored) - if you soak an old sock in thickened epoxy and let it dry I bet you can whack it pretty hard with that screwdriver and it will feel pretty solid. But even the crazy cheapskate doesn't build or repair boats with old socks...
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
arbarnhart is offline
post #50 of 55 Old 06-26-2008
Freesail99's Avatar
I understand what Stu means. I repeat, All you have is a surface coating of epoxy over the mat. It will feel hard but it will not have any strength.
S/V Scheherazade
The complete anchoring hand book.. AlainPOIRAUD Learning to Sail 5 10-29-2006 05:07 PM
