Im a complete IDIOT! - Page 6 - SailNet Community
post #51 of 55 Old 06-26-2008
arbarnhart's Avatar
Originally Posted by Freesail99 View Post
I understand what Stu means. I repeat, All you have is a surface coating of epoxy over the mat. It will feel hard but it will not have any strength.
I wouldn't call it a surface coating. It's over, under, around and between the bunches of fibers. The mat gets soaking wet with epoxy. I know because I have done it. That's why I thought it worked. I soaked the mat then put it in the void and there was epoxy all through it. But I didn't know that the mat should have started pretty much disintegrating. But this is from what I read the other day and I could just be digging my hole deeper.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
arbarnhart is offline
post #52 of 55 Old 06-26-2008
The epoxy isn't adhering to the bundles of fibers...it is adhering to the sizing that is holding the bundles of fibers together... big difference. It is basically a surface coating and the major difference is simple. In a true laminate, like using polyester resin and CSM—the fibers can no longer move relative to one another as they are encased and adhered to by the surrounding resin. In the case of using CSM and epoxy, the epoxy is adhering to the binder coating, but under high stress loading the fibers may shear their physical connection to the binding sizing, which isn't really all that strong as a material or as an adhesive, and the fibers will then be able to move relative to the material surrounding them. Which do you think is stronger???
sailingdog is offline
post #53 of 55 Old 06-27-2008 Thread Starter
I was never argueing it was stronger.
I know i probably come across as someone who is just argueing until he gets the answer he wants,
but ive been see sawing back and forth on this one between posts.
The phrase "the fibers may shear their physical connection to the binding" is quite alarming.
But if you look at the pics you can see ive only done the inside of the hull so far. If that was it, i think you'd be right. It might be alright, but you dont want to worry about it dropping of a wave or bumping on a beach/trailor.
Im gonna wait for the approriate material arrives to do the outside.
I guess I just dont see the the csm epoxy coming apart, especially as the edges and the right angle to the bulkhead are taped with the correct material. And what damage might i do ripping it all out?
With Biaxial Tape 150 mm 430gsm on the outside of the hull it will be far stronger than the surounding wood.
Thanks for all the posts. Although im being stubborn and arguementative i do appreciate them.
stu9000 is offline
post #54 of 55 Old 04-16-2009 Thread Starter
It didnt fall apart
For those that might still care...
a year on and its still holding together.
To be fair, its been wintering under a cover for a lot of that time, but ive had a few hard trips out.
This was always going to be a bit of a messy learning curve project. The boat was almost dead when i got her and i learned a lot about bot epoxy and polyester along the way.
I got away with it because the weak epoxy csm mix repair on the inside of the hull was not part of the structural strength of the boat. That was achieved using the correctly mixed matt and epoxy on the outside of the hull.
The helpful advice i have received warning me not to believe in the strength of my bodged inside repair is correct. How wise i sound now after the fact.
As a general point I believe anyone reading this post should and wondering what the hell were all talking about should not be deterred. There is no substitute for getting your hands dirty and having a go. Worst case scenario is the boat breaks under me and i have to swim to shore. Ill bet its not gonna happen and even if it did its a great story for sailnet (as long as im wearing a life jacket). Im safety conscious, but i also believe in getting on and learning! This balance is every individuals personal choice.
stu9000 is offline
post #55 of 55 Old 04-21-2009
It won't cure properly!!! I did the exact same thing. I was fixing a hole in my hand-me-down dinghy and mixed it wrong. That was a month ago. Its still gooey. In fact, it rained and the stuff ran down the side of the dinghy. Best to scrape it off and do it properly!
Teresa
Sailing, Simplicity, and the Pursuit of Happiness
LittleFlower is offline
The complete anchoring hand book.. AlainPOIRAUD Learning to Sail 5 10-29-2006 04:07 PM
