06-21-2008
I like golfcart batteries and use Trojan T105s for my house bank. However, if you're planning on long-term cruising, AGM batteries might make more sense, due to their higher charge acceptance rate—which results in faster recharge times (at least to the 85% level) and less engine run time if you're using the engine for recharging and have high-output alternators.
If you're just weekending or coastal cruising, then it doesn't matter too much, and going with the golf cart batteries is probably going to be easier and cheaper than AGM batteries. BTW, T105s make a lot more sense IMHO than 4D or 8D batteries, since they're a lot lighter per battery and less likely to cause you to rupture something trying to put them in place.
