06-22-2008
Originally Posted by saurav16
can you mate marelon seacock to bronze thru-hull? I understand that all marelon fittings are NPS and the bronze seacock is nps as well. Any thoughts?
If you have an NPS marelon ball valve, which is rare, and an NPS thru-hull NO you can not mate these two together!
Yes they WILL go together but NPS-M threads are "mechanical" only as in NPS-M, M for mechanical. Mechanical threads, are not, and were NEVER intended to seal against positive pressure or to be water tight!
NPT & NPT (tapered) threads mate together to SEAL OUT, (or in) water!! NPS & NPT is a dangerous mis-match but it will, sort of, seal out water..
______
-Maine Sail / CS-36T
