Old 06-22-2008
Slayer's Avatar
Slayer is on a distinguished road
Divot repair
I have a small 13" Chrysler Pirateer. It is an old boat that I got pretty cheap. I sail it in a small lake in my backyard. There are a couple of small, but pretty deep divots in its hull above the water line. I see not blistering around them so I don't think a lot or any water has gotten under the surface.
This is an old, inexpensive boat, so I am looking for a cheap and quick repair, if nothing more that will last this season. What should I fill the divots with?
Old 06-22-2008
ereuter's Avatar
ereuter is on a distinguished road
I would get some West System epoxy+hardener and some of their colloidal filler. Mix the epoxy and hardener according to the directions, then add filler until it's the consistency of peanut butter. Use a putty knife to fill the divots. You can sand it afterwards and paint if you like.
I'd recommend the fast drying hardener for this application, or it will take forever to set up.
Eric
"Figment" 1978 Pearson 30 #1083
Old 06-22-2008
Zanshin's Avatar
Zanshin is on a distinguished road
I've never heard the term "divot" used in the same sentence as a sailboat, so I have this visual image of someone whacking at the hull with a 9-iron.
Old 06-23-2008
LakeEscape is on a distinguished road
Bi-Polar Sailor
Another sailor with strong emotional battles. It's a beautiful day, do I go sailing or do I go play golf? I joined a self help group to deal with this problem. We meet regularly at a bar between the marina and the first tee.
LakeEscape
Old 06-23-2008
RestlessWind is on a distinguished road
Your "divots" really can't be all that big on a 13" boat. You might try a piece of bubble gum as long as they are above the waterline. Oh, and keep your sailboat out of the kids swimming pool when you're playing golf.
Old 06-23-2008
arbarnhart's Avatar
arbarnhart is on a distinguished road
I strongly recommend against fast hardener when filling a cavity because of the heat produced. Epoxy still sets up in about the same amount of time even when there is a large amount. I build a pirogue (like a canoe) and I put about a pint inside each point with 12 hour hardener and it was solid the next day. That's a common technique for building sea kayaks and I thought it sounded like a good idea. After seeing my kids ram the dock a couple of times, I am sure it was.
I have some generic "epoxy thickener" that was sold as a silica alternative that is great for that type of repair, but so is silica. Be careful to try to scrape it smooth and leave yourself as little sanding as possible.
BTW - ask around about whether or not the polyester repair kits would work for this. I don't know. But they are cheaper and easier to find.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
Sail Repairs at Sea Brian Hancock Gear and Maintenance Articles 0 09-22-2003 08:00 PM
Sail Repair 101 Don Casey Gear and Maintenance Articles 0 03-10-2003 07:00 PM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
Sail Repair at Night, Sailor's Delight, Part Two Don Casey Gear and Maintenance Articles 0 03-16-1999 07:00 PM
