06-23-2008
Yes Gary, the outer nuts lock the gland after adjustment. Just back those off, tighten the inner nuts (just a little bit at a time!!), then retighten the outer lock nuts. Make sure you don't overtighten the gland. You should get an occasional drip when running. Using two wrenches - one to hold the inner nuts while you tighten the outer ones - is the way to go.
