Pitch Black Exhaust Water Yanmar 2GM20F - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 06-23-2008
badsanta is on a distinguished road
How is it in neutral at higher RPM? Does it still smoke? if not check that prop. Something wrapped around it will cause it to smoke. Or a clog in the exhaust elbow will do it also. If it ran fine last week and now it does not that in medical terms is an acute problem, as in a sudden on set. If you did not ad fuel from last time to this, I would change the filters yes but don’t overlook the exhaust elbow and the prop.
  #12 (permalink)
Old 01-25-2010
hbergold's Avatar
Tweety
hbergold is on a distinguished road
Hi Rireefguy
I have the exact same engine with the exact same problem. Did you find what was wrong? Please advice before I end up disassembling the injectors.
Thanks in advance
Henning
Originally Posted by rireefguy View Post
So I had some problems with my Yanmar 2GM20F today. I actually first noticed it the last time I took the boat out. The water coming out of the exhaust is PITCH black. Looks like dirty oil, but no slick. I changed the oil last weekend and the oil level has not changed. So I was out today and I was motor-sailing with the engine turning around 2500rpm when I noticed it again. I went down to idle and it goes clear again. Then (at the worst possible moment) the engine started running funny and was only turning 1200rpm at the same throttle position. I tired to throttle up and it bogged down. Ended up shutting it down and sailing home. Additionally, it has been a little hard to start. I dont have anything to base this on as it is a new boat to me and my first diesel but it just seems longer than I would expect, especially when the engine is cold..
Here is what I am thinking:
I think this is a fuel issue. The PO said that he never let it get down to 1/2 a tank, and would always keep it topped off. I now think that he may have been doing this for a reason. (I am currently at just under a 1/2 tank (was going to fill up today but never made it =))
I also thought about draining the tank and will probably still do that if this works.
The plan:
Going to change the fuel filters tomorrow and fill up with fresh diesel. See what happens
Does this sound like I am in the ballpark or am I totally off base. I am kinda new to diesels. If that doesn't do the trick where do I look next, etc.
Thanks in advance!
  #13 (permalink)
Old 01-26-2010
hbergold's Avatar
Tweety
Same problem, any advice from someone?
Greatly appreciated
Henning
The plan:
Thanks in advance!
  #14 (permalink)
Old 03-03-2010
cfoxcvg is on a distinguished road
"hbergold"
Check the Prop. I had only a couple barnacles and it was about 30% of my problem which is the same you are having. See my post on "Cruisers Forum"
Yanmar 2gm20f - Black Water at 2700+ RPM by cfoxcvg
Unless you recently worked on the injector pump then disregard the talk about the shims. It only takes a couple little barnacles on the prop to over work the little 2gm20 but if the prop is clean she will work her but off.
  #15 (permalink)
Old 03-03-2010
hbergold's Avatar
Tweety
I will check this next weekend. I’ve heard the prop suggestion in other posts, but was lazy to get wet. I checked the mixing elbow (which wasn’t in bad shape), cleaned it, but the black smoke remains at 2700rpm. Will let you know. Thanks
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 09:10 PM
Windward performance deseely General Discussion (sailing related) 16 01-28-2010 07:16 PM
raw water pump leak on Yanmar 3Gm30F gsyversen Gear & Maintenance 24 06-13-2008 02:34 AM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 07:55 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
