Old 06-23-2008
kenhoneycutt's Avatar
Lake Michigan
kenhoneycutt is on a distinguished road
Yanmar 3MY30 oil capacity
This is dumb question I know, but does anyone know the approximate capacity for a 3MY30. Can't seem to find my maintenance manual and I need to top off the level. I drained 3 liters out this weekend and replaced with a little over 3 for the filter but the dipstick is still showing on the lower dot. I thought the manual said somewhere around 2.8 Liters but maybe I was off by a liter?
Need to find that @#$% manual.
Hunter 36
Old 06-23-2008
Boomer08 is on a distinguished road
Ken,
Oil capacity is 2.8 L or 3.0 qts. Info can be found on page 25 in Operation Manual. If you have lost yours I belive you can download a copy from the Yanmar site. Wait 10 minutes for the oil to drain back into the pan, and be sure that the dipstick is pushed all the way down before you check the level.
Old 06-23-2008
JohnRPollard's Avatar
Moderator
Originally Posted by Boomer08 View Post
Ken,
That's right. Same as the earlier 3GM30F.
As for the low reading on the dipstick, is the boat possibly listing to port?
Old 06-23-2008
Lake Michigan
Thanks for the responses
Sounds like maybe I didn't let the oil drain down into the pan long enough.
Hunter 36
Old 06-24-2008
scottbr's Avatar
scottbr is on a distinguished road
Is that 2.8L with or without the filter. I can't remember if the filter has an affect on the level?
Out of curiosity, why are there two yellow "Engine Oil" caps?
Old 06-24-2008
Lake Michigan
Wondered about those two yellow caps myself
I watched the video on the Yanmar website on maintenance procedures. They show both yellow caps but they only show oil being added to the top fill. I'm assuming that it is just another fill spout in case you can't access the top filler for some reason? Kind of scared the sh!t out of me when I first saw it and thought maybe I had to add some quantity of oil there for some reason (I hadn't studied the manual all that closely).
Hunter 36
Old 06-24-2008
Lake Michigan
Oil Filter
Don't remember any mention of the oil filter either on whether that is counted in the 2.8 Liter..I added a little extra after I saw that ~ 3 liters drained out without the filter removed.
Hunter 36
Old 06-25-2008
scottbr's Avatar
I wondered as well that it might be for convenience depending how the motor is mounted. I watched that part of the video several times before adding oil to make sure they were both the same.
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
What oil for Yanmar engine trantor12020 Gear & Maintenance 26 04-21-2008 03:50 PM
1983 Yanmar 1GM engine -- Oil for Gear Case H216Sailor Gear & Maintenance 11 04-05-2008 09:56 PM
oil capacity yanmar2gm13? pearson303 Gear & Maintenance 3 11-14-2003 03:15 AM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
