06-23-2008
I had 1/2" before and was looking to improve isolation also. I went to 3/4" and no good results at all. I learned that size matters, so go for the thickiest room and budget allow; use one that include thermal isolation. I found that leaving non insulated gaps (pannel joint, openings, floor, etc...) really frustrate your entire work, so pay a lot of attention to the finish and make sure you cover as much as you can, without gaps. If you go that way, it will demand blower installation as well, but you'll be glad with results.
Nave Rara
Beneteau Oceanis 43 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
