Old 06-23-2008
Irrationally Exuberant
arf145 is on a distinguished road
Battery switch exposed back
Boat has a 20-yr-old Guest master switch mounted low on a stowage bin face with the guts of the switch in the bin. While looking for a tool or part over the weekend happened to look in that bin and notice for the first time that the switch contact nuts are exposed. I assume that anything metal shifting in that bin could short things out or worse. Do these switches usually have a housing over the connections?
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 06-23-2008
Considering that most battery switches are just positive leads, unless there is a ground nearby, the risk of shorting is relatively low. I'd still recommend putting a plastic cover over the back though. A small plastic container, like a tupperware container, will often fit quite well and do the trick.
Old 06-23-2008
Of course it's positives! Didn't even consider that. But I like your bowl thing anyway--I'll size it up for a cover next time.
Thanks.
arf145
1987 Pearson 28-2
Chesapeake Bay
Choosing Batteries Kevin Jeffrey Gear and Maintenance Articles 0 04-07-2003 08:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
A Little Help from the Sun Don Casey Gear and Maintenance Articles 0 12-20-2001 07:00 PM
A Little Help from the Sun Don Casey Cruising Articles 0 12-20-2001 07:00 PM
