-   -   Replacing Teak Flooring (http://www.sailnet.com/forums/gear-maintenance/44367-replacing-teak-flooring.html)
Trescool 06-23-2008 02:26 PM
I have two small sections of teak(?) laminated flooring in my 1994 Catalina 270 which have previous-owner water damage. It is warped and needs replacing.
Where do you find replacement flooring? Or is it pretty easy to buy supplies (i.e. teak laminate) to build myself?
camaraderie 06-23-2008 05:42 PM
Is is laminated teak and holly on plywood? If so, just buy a sheet or half sheet and fabricate your own...easy job. SEAL the plywood with epoxy to prevent future water intrusion. Try Ultimate Sole as a coating for the teak/holly if you don't have to match something else.
Sources for teak ply are here if you do a search.
