08-09-2010
Forespar Marelon winches
Yes Bob -- in my experience they all stick, even to the point of seizing. They have a one piece mount with a marelon post, a bronze bushing, and a drum. The bushing is a force fit in the drum, and turns on the post. I just worked on two that had seized the bushing to the post and were turning the drum on the bushing (but very hard to turn). I just reamed out the drum a bit with a 1" drum sander and let them turn free on the bushing. since it's bronze on marelon either way, I doubt if it matters. Alternatively, you can sand the post a bit if the bushing will come off with the drum, as was the case on another pair. I think they are made to too tight a tolerance, and the marelon swells a trace. Fix that, and they work fine. Just unscrew the center screw and lift off (or pry off) the drum. Read the instructions and make sure you replace the screw retainer "core bushing" properly. And don't sand or ream them too much, or they will get too sloppy of course. I just roughed it up a bit, and I am supposing it will then wear in again to a nice lose fit. Apparently the bronze/marelon mating requires no lubrication.
