Old 06-23-2008
Hunter07 is on a distinguished road
Question Need help replacing deck hardware on a Catalina 30
I have a 87 Catalina 30 tall rig and the rope clutch for the main halyard is shot. I also want to add a clutch for the jib halyard on the port side. The current clutch is not thru bolted but the rigger that worked on my boat said that Catalina had embedded aluminum blocks or plates in the deck for mounting this hardware. Does anyone know how to bolt new hardware on? Do I need to drill holes and tap threads?
Old 06-23-2008
rperret's Avatar
rperret is on a distinguished road
try garhauer - they are the oem supplier to Catalina. they are known for good to very good quality components at price points below harken, schaeffer, et al.
Old 06-23-2008
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
+1 for Garhauer, give em a call they treat you like family.
Merit 25 # 764 "Audrey"
Old 06-24-2008
Actually, for rope clutches, I'd recommend LEWMAR, not Garhauer. They're less expensive and have consistently rated higher in performance and lower in line abrasion in tests. Unlike some of the other brands of line clutches, the Lewmars can always be eased under load. The Spinlocks and some of the others have to have the load eased on the line before they will release. It would be worthwhile to check out the last line clutch review done by PS Magazine. You can read it here.
Old 06-24-2008
knothead's Avatar
If there is an embedded aluminum plate, then yes, drill and tap. It's a really clean and easy way to attach deck hardware.
Be sure to apply a locking compound such as lok-tite or tuff-gel to the threads of the bolt and use a little bedding around the hole as well.
You don't want water getting in.
Ron Paul 2012
"wikijar"
Old 06-24-2008
Barking Dog
KindOfBlue is on a distinguished road
In addition to all the advise here, you can also post to the Yahoo Catalina 30 group available at Catalina30 : Catalina 30 Owners Online List
You will find out for sure if there is an aluminum plate over on the yahoo group.
Craig
Replacing wood "curtain" with wood door in head area? Catalina 27 7tiger7 Gear & Maintenance 25 07-29-2007 11:24 PM
replacing non skid on large repaired (deck) surface geary126 Gear & Maintenance 4 09-30-2006 04:33 PM
Installing Treadmaster Nonskid Sue & Larry Cruising Articles 0 07-11-2004 08:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
The Catalina 310 Micca Hutchins Buying a Boat Articles 0 10-07-1999 08:00 PM
