Old 06-24-2008
davidpm's Avatar
davidpm is on a distinguished road
Roller Furling problem
My friends Catalina 30 has a couple of problem on the Roller Furling unit. The bottom track is bent and the top is said to look like someone took a can opener to it. The result is that it is a challenge to roll up and the sail will not drop unless someone goes up the mast to release it.
Does it make sense to replace two sections of track if the rest of the unit is OK or replace the whole unit?
Old 06-24-2008
knothead's Avatar
It may make sense depending on the model and age.
It sounds like a system that has had halyard wrap with a wire halyard. That will need to be corrected also.
Ron Paul 2012
"wikijar"
Old 06-25-2008
davidpm's Avatar
It has a rope halyard. The cause of the damage to the top of the extrusion is unknown.
Old 06-25-2008
knothead's Avatar
There generally aren't too many things that will tear up the top of an extrusion the way you have described.
It should be possible to determine what caused it.
Could there have been a wire halyard on the boat previously? There are usually telltale signs of that.
I don't really know what to tell you because you haven't told me much about the unit.
To determine whether or not it would be prudent to repair or replace a furler, we need to know what kind it is, how old it is, and what's wrong with it.
You have only shared one of these things.
edit; if you can take a photo of it, that would help.
Ron Paul 2012
"wikijar"
Old 06-25-2008
davidpm's Avatar
I'll try to get a picture tonite.
Old 07-08-2008
davidpm's Avatar
The picture thing is not going to happen unless I get a telephoto lens. Apparently the boat had a wire jib halyard at one time. The top of the roller furling extrusion was ripped up a bit and the new rope halyard would get snagged on the rough protrusions on the extrusion. We fixed the problem by riveting a block with a spring about 8” down from the top of the mast.
This way the halyard goes over the mast head sheeve then straight down to the new block then out at about 45% to the furling extrusion.
The angle makes is possible to tension the sail but makes it unlikely for the halyard to wrap.
Seems to work and I notice that about ľ of the boats have the same setup.
Old 07-08-2008
Rockter will become famous soon enough
Get a price on the new sections. Complete units are very expensive.
Old 07-08-2008
You're going to want to replace the foil sections. It ain't rocket science... call up the manufacturer and see if the foils are available.
Old 07-08-2008
davidpm's Avatar
They are not we checked.
Maybe if the captain keeps the boat.
Old 07-08-2008
If he is keeping the boat, it might be a good idea to get a new furling unit.
Roller Furling Problem: HELP! OhioSailor Gear & Maintenance 13 05-18-2008 05:12 PM
Climbing the mast ... to bix a roller furling problem... marinesniper Gear & Maintenance 16 02-02-2007 09:46 PM
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 08:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 08:00 PM
Boom Furling Revolution Tom Wood Cruising Articles 0 07-12-2002 08:00 PM
