06-27-2008
ChrisandTammy-
The line is probably either Dyneema or Spectra-based. They're considerably stronger than steel wire, with about the same stretch. For example, 6 mm Endura 12 single braid, made of Dyneema, has a breaking strength of 8500 lbs. 6 mm 316 1x19 stainless steel rigging wire has a breaking strength of about 2900 lbs.
