Old 06-25-2008
kgs113's Avatar
kgs113 is on a distinguished road
Marelon and polysulphide
Just drilled a hole in a perfectly good hull to install a bilge pump. Is Life caulk a good choice for sealing a Marelon thru hull that's above the waterline?
Old 06-25-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Yes it is......watch the cure time and don't cheat on it
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 06-25-2008
Should work fine. Polysulfide sealants do attack some plastics, but Forespar says that Marelon is compatible with all marine grade sealants, so should not be one attacked by the polysulfide compound.
