Old 06-25-2008
svey is on a distinguished road
O'Day 23 boarding/swimming ladder
I'm installing a boarding/swimming ladder on my 1976 23' O'Day. I drilled 2 holes yesterday on the transom 20" from water level (starboard side). To my surprise, it doesn't look like I've gone through any core material. Just the 2 layers of GRP. Is it possible that the core material doesn't go that high? I know there was balsa on the starboard side lower section where my motor lift is installed because I had to tear and rebuild that portion because of water intrusion and rotten balsa.
Now for the big question, how can I install the ladder? I've made a 14" x 5" stainless steel "washer" for the outside portion and 2 6" x 5" "washer" for the inside. The right bracket falls inside the cockpit bench/locker so I will build a large GRP backing plate with epoxy and mat to distribute the weight. But how can install the other bracket if there is not core material?
Old 06-25-2008
It will involve a bit of work, but you'll have to cut out a section of the area of the inner fiberglass, and then laminate in some support material or pour thickened epoxy in the area, and then re-fiberglass the inner side.
Old 06-25-2008
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
You're right Svey, I found same on my previous 1978 O'Day 23. There is a reinforcement for the motor lift (what I replaced that time) specifically around mounting area. The rest is plain GRP and void between 2 layers, as I installed antenna mount, and reaching lights. On our marina, several had transon platform (practical, but many weird ones) so I decided for removable Gunwale-mount ladder, that allowed me to use it also on bow, when aground on a calm beach.
Nave Rara
Beneteau Oceanis 43
Oday 22 Ostervilleboater General Discussion (sailing related) 5 11-02-2007 08:09 PM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
ODay 27 for $500? Decent boat? 7tiger7 Boat Review and Purchase Forum 11 02-13-2007 09:08 PM
O''Day "rOnDAYvous 04" maestro General Discussion (sailing related) 2 07-11-2004 04:50 PM
oday 30 purchase RobGallagher Boat Review and Purchase Forum 1 09-13-2001 05:08 PM
