Old 06-25-2008
harpguitar is on a distinguished road
Battens? Use or not?
Just bought an old Westerly 26'. The mainsail came with battens. They are about 3ft long and insert in the leach. I have read where some think that they are not necessary. What do folks think?
Old 06-25-2008
knothead's Avatar
If you have them, you should use them. They will improve the shape of the sail.
Ron Paul 2012
"wikijar"
Old 06-25-2008
poltergeist's Avatar
Poltergeist
poltergeist is on a distinguished road
Use them ... your sails will probably last longer, too, since they won't be flogging around as much.
kurt
Old 06-25-2008
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Yeah, keep it. Would be even better a full batten arrangement, but it's better than none. Try it on and off, then note the improved shape on little wind conditions ... it's unbeatable !
Nave Rara
Beneteau Oceanis 43
Old 06-25-2008
tommyt is on a distinguished road
The sailmaker designed them in for a reason. Sail shape, especially light air sail shape, is much improved.
A question: If you have them, why are you thinking about not using them?
Old 06-25-2008
merlin2375's Avatar
*starboard*
merlin2375 will become famous soon enough
why not
I sail.
Old 06-25-2008
beej67's Avatar
beej67 is on a distinguished road
Just replaced my partially battened main with a fully battened one. Can definitely see the difference.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
Old 06-25-2008
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
There are two possible questions here:
The first, is theoretical, "Should I have a battenless or battened main." Larry Pardey is an advocate for a battenless main because the battens in their pockets are a source of chafe and as he sees it you get such a small benefit from the increased sail area as to not be worth it.
The second question is directly related to your situation now, "Should I insert these battens in the sail I have." The answer to that question is undoubtedly YES. The sail you have has been cut for battens. In order to have a battenless main you need to specify at its time of construction that the leech be "hollow cut" or "sweedish cut". This means that instead of the leech making a straight line (or bulging out) it curves inward.
Since your sail has battens and pockets it is NOT hollow cut and unless you re-cut it it will not fly right without the battens. What will happen? The leech, unsupported by battens, will flitter. flap, flog and flap causing decreased performance as it disturbs the air at the end of the sail. More to the point the flogging in winds above 10kts will destroy the leech of the sail in a fairly short time, thus negating the idea of a low maintenance, battenless sail.
You can always, for educational purposes, hoist it (in moderate air) with and without the battens and see for yourself what it looks like and what happens. If you really want a battenless sail, talk to your sailmaker about re-cutting your sail.
Congrads on your new boat!
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
Old 06-25-2008
Thank you everyone! Tommy T. asked why I had considered not using them...the answer is that I had been doing some reading and one book suggested they did not serve a purpose and to leave them out. Your replies make perfect sense however and I will proceed with the battens. I will probably try it both ways out of curiousity at some point.
Thank you again
mainsail roach, battens, weather helm, and mast placement stipakb Sailboat Design and Construction 10 09-08-2008 06:30 PM
tapered battens Randolph Bertin Gear & Maintenance 4 02-01-2007 06:55 PM
Tapered battens ltdavis Cruising & Liveaboard Forum 1 02-01-2007 06:05 PM
Main Sail Battens ronbrockman Racing 3 10-28-2001 09:08 AM
Mainsail Details Brian Hancock Gear and Maintenance Articles 0 06-19-2000 08:00 PM
