Replacing Impeller - Page 2 - SailNet Community
post #11 of 26 Old 06-27-2008
Haven't done our A4's impeller yet, tho I should probably do so--if for nothing more than the experience/practice, so please forgive the question, but what is the zip tie or string for?
Jim
SEMIJim is offline
post #12 of 26 Old 06-27-2008
To keep the blades of the impeller slightly bent so that the impeller goes into the opening easily.
sailingdog is offline
post #13 of 26 Old 06-27-2008
Ah hah! Cool! Thanks for the tip
Jim
SEMIJim is offline
post #14 of 26 Old 06-27-2008
JIm-
Just to illustrate the point:
BTW, make sure that you've pre-bent the impeller vanes in the correct direction. Not so good for the impeller if you've gotten that backwards.
post #15 of 26 Old 06-27-2008
the pointy end is the bow
erps's Avatar
Do impellers turn the other way in the southern oceans?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #16 of 26 Old 06-27-2008
Only when you're motoring backwards.
post #17 of 26 Old 06-27-2008
Barking Dog
I use silicone grease because someone told me that Vaseline (petroleum jelly) or dish soap (also petro based) and rubber do not mix. Now that I think of it, petroleum is use and the making of automobile tires.. Maybe it's petroleum and latex that don't mix. In any case, I use silicone grease on my impeller.
As for removing, my PO left me a impeller puller. I find it very useful. Before I discovered what it was, I used needle nose pliers and the puller makes a big difference on my Yanmar 4JH. I never had problems pulling off the impeller with pliers on my old Universal M3-20. So first try pliers and if you find it difficult, invest in an impeller puller (Jabsco makes them).
Craig
KindOfBlue is offline
post #18 of 26 Old 06-28-2008 Thread Starter
Replacing Impeller
Well, for what it is worth, the Oberdorfer 202M 07 water pump does have a circlip that holds the impeller onto the shaft. The shaft, however slids out quite easily, making removal of the circlip a piece of cake. I don't think I could do it while it was inside the water pump housing. It is also very easily reinstalled with the tie-wrapped, circlipped impeller in place on the shaft. Couldn't find the paper thin gasket that is listed in the distributers parts book, nor could I find the very thin paper gasket material, so I used a liquid gasket material intended for water pumps. I'll see tomorrow how well that works as it takes 24 hours to cure.
Thanks for the input
ccriders is offline
post #19 of 26 Old 06-28-2008
Sea Slacker
I have Yanmar 4JH and had no trouble removing old impeller with pliers - not even needle nose, just regular pliers - I don't care if I damage it, it's going into trash anyway Just grap a blade and pull.
brak is offline
post #20 of 26 Old 06-28-2008
I recommend not damaging the impeller if at all possible, since they can often, if they are still in good shape, serve as an emergency backup. And yes, some of the plastics/rubbers used in impellers can be damaged by petroleum based products, like Vaseline.
Impeller Trick Cruisingdad Gear & Maintenance 17 05-21-2008 04:00 PM
3JH2 Yanmar Impeller RickBowman Pacific Seacraft 2 03-09-2007 06:10 PM
Replacing a sail drive impeller Risley Gear & Maintenance 1 07-07-2003 09:21 AM
Replacing Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-22-2000 07:00 PM
