Replacing Impeller - Page 3 - SailNet Community
post #21 of 26 Old 06-29-2008
ummm, uhhh, the zip ties are a good idea, sting, anything to "pre install" is a good idea.
As far as pre-lube, i used to use vasoline, but ummm, uhhh, try one of those "personal" lubricants... very slippery.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #22 of 26 Old 06-29-2008
moderate?
camaraderie's Avatar
Rather than the KY I prefer the built in lubrication and RUN DRY capability of the Globe brand impellers. Some people have had bad luck with them but most swear by them and they do compensate for the occasional lapse of memory at the through hull! Here's an excellent article on them AND how to change an impeller.
http://www.sailmag.com/boatworks/bw08.impeller.pdf
camaraderie is offline
post #23 of 26 Old 06-29-2008
Thanks for the hint, Cam. I'll have to look into this.
Some people have had bad luck with them ...
What kind of "bad luck?"
Jim
SEMIJim is offline
post #24 of 26 Old 06-29-2008
moderate?
Some claim premature failure..generally not the loss of a "wing" but rotation of the rubber on the center section. I have not found this issue and they do not degrade in the "rubber" part anywhere near as fast as the black ones. As they are so cheap, I always carry spares but have only had good experience and no need to replace as often as the black ones.
post #25 of 26 Old 06-29-2008
Maine Sail's Avatar
I had two Globe impellers spin the hub on a Universal M-25. I went back to the regular impellers. In theory they are a great idea but after two spun hubs at the most inopportune times and I had no choice but to go back to regular impellers..
I change mine every year.. Five minutes and never a head ache..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #26 of 26 Old 06-29-2008
Impeller Replacement
I will probably start a real argument, but on some motors the impeller shaft can be removed making replacement of the impeller much easier. My universal 18 is such a motor. Check the Universal web page at Torrenson (sp), Mechanics debunk many myths. You can remove the brass constrictor (not the correct term, but my info is on the boat) for ease of replacement as well. A hose clamp tightened down with the impeller center, and on the shaft, simply slide in and refit, replace constrictor. Oil a little replace gasket, and cover with a thin film of oil and replace cover. Get spare screws as these are easy to drop and become lost in the engine compartment.
Mark1948 is offline
Impeller Trick Cruisingdad Gear & Maintenance 17 05-21-2008 04:00 PM
3JH2 Yanmar Impeller RickBowman Pacific Seacraft 2 03-09-2007 06:10 PM
Replacing a sail drive impeller Risley Gear & Maintenance 1 07-07-2003 09:21 AM
Replacing Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-22-2000 07:00 PM
