Old 06-25-2002
R33 R33 is offline
R33 is on a distinguished road
Shaft Log Leak
Noticed a little less than a teaspoon of water beneath the shaft log hose at the end of the day. Sometimes none at all-may depend upon prop rotation/engine use . The hose is damp to wet aft the double clamps water is getting through. Pull the boat/watch and wait? Thanks for the input.
Old 06-25-2002
Jeff_H's Avatar
Super Moderator
Shaft Log Leak
Depending on the type of shaft log that you are supposed have an occasional drip at the shaft. This is what lubes the packing. With the slope of the shaft this water can drip aft and wet the hose. You need to figure out if this is a normal leak or something more serious by watching the shaft while it is turning.
Old 06-25-2002
R33 R33 is offline
Shaft Log Leak
Jeff,
Thanks for the reply however the water is not leaking at the packing nut, which is the usual location. If memory is correct, we usually get a drop every several minutes between the packing gland and locking nut. Thats the same as always. Im noticing water further aft where the shaft exits the log and is surrounded by a hose about a 8 inches in front of the packing nut.
The exterior hose surfaces appear dry. The hose over the molded glass log at the bottom aft end is damp to wet at times. I dont see a trail of water along the exterior surafces of the shaft. Also the hose clamps are tight.
Old 06-26-2002
lecomte38 is on a distinguished road
Shaft Log Leak
looks like something to put on your "next haul out" list. Please use the proper hose. It is about 15 ply stuff and isn''t too expensive.
Old 06-26-2002
VIEXILE is on a distinguished road
Shaft Log Leak
Back in ''99 I watched a completely refurbed, painted and ready to rock old Morgan 50 OI style launched for extended cruising here in STT. Next morning it was back in the slings. Within an hour of launch, the bilge was almost full. The shaft log is just a fiberglass tube, suceptible to vibrational stress. This one broke free on one side. It had to be completely reglassed and restrengthened. Would''ve been a real mess had they made the corner into the deep. If you remotely suspect your shaft log is the culprit, I''d suggest hauling, carefully inspecting the tube and, if o.k., replace the gland and packing. I know it sucks, but so does finding a travel lift off-hours.
rain leak in MacGregor 26x newuser Gear & Maintenance 7 09-20-2009 11:43 AM
Shaft Zinc FlySwat Gear & Maintenance 6 06-11-2005 04:15 PM
Shaft Vibration in Forward but not reverse bstrebe Gear & Maintenance 6 10-28-2003 07:17 AM
Shaft Pump? knothead Gear & Maintenance 4 08-05-2003 08:31 AM
long or short shaft? lee_1999 Gear & Maintenance 6 04-17-2003 06:06 PM
