Old 06-25-2008
Loualfr is on a distinguished road
jib issues
I had a really hard time hoisting my furled jib on the headstay last year and even harder time getting it down. this year I can't get it more than halfway up the forestay, I'm planning on putting some sailkote on the sail but are there any other suggestions anyone has for this? thanks!
Old 06-25-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
If the Halyard had jumped the sheave it can become jammed between the sheave and the masthead fitting
Old 06-25-2008
Lou-
Generally, if something takes a lot more force than it normally used to, something is wrong and instead of bulling ahead, you need to figure out what the cause of the problem is.
For example, my friend was having a hard time with their headsail furling unit and decided that using a winch on the furling line was good idea. It's not. They had a halyard wrap and the winch allowed them to destroy the top section of the furler foil and the headstay. If they had looked up, it probably would have been much less expensive a day for them. Next week, I'll be helping them replace the forestay and repair the furling foil.
Old 06-25-2008
ASA and PSIA Instructor
Sailcoate in the furler track can make all the difference. Hard to grease the grooves once the mast is up tho. My jibs go up full hoist by hand at the beginning of the season, by midseason I need to resort to winch power for the last third or so...So needing more than hand power is not an uncommon syndrome. But as advised be sure that nothing is fouled...
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 07:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Seamanship Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Gear and Maintenance Articles 0 05-10-2000 08:00 PM
