Galvanized Anchor Refinishing - Page 3 - SailNet Community
post #21 of 23 Old 10-21-2011
skygazer's Avatar
Originally Posted by JimsCAL View Post
Three year old thread. I think the Baha cruise/race is over.
Anchors and galvanizing are still of current interest.
skygazer is offline
post #22 of 23 Old 10-21-2011
JimsCAL's Avatar
OK. But better to start a new thread focused on the question at hand rather than force us to read old an old thread that may gone off topic a bit (like this one did).
JimsCAL is offline
post #23 of 23 Old 10-21-2011
skygazer's Avatar
I suppose it depends on whether you consider the thread to be about a particular race, which seems a side issue, or about hot dipping rusty anchors. I read the thread with interest, I have 4 or 5 anchors and chains that are rusty. I do agree anchor size is off topic, but that is not related to the newer posts.
I find it educational that hot dipping zinc is charged by the pound. Chain has a much greater surface area to cover per pound than an anchor, will use a lot more material and it will be harder to remove excess.
Given the poundage, I could buy a lot of cans of cold galvanizing compound and recoat the anchors many times for the price. Looking at it as sacrificial zinc, I'm not sure which way is better. The chain, I'd let them do it!
Here is the original title:
Here is the original post:
Originally Posted by Vitesse473 View Post
Is it possible to grind a galvanized anchor down to its bare metal and refinish it? If so, what do you refinish it with to protect from rust?
I also found this to be educational:
Originally Posted by pistoljr View Post
Thermal spray with Zinc/Alum is a better process for refinishing an anchor. It is sand blasted to remove rust and then sprayed with with hot liquid Zn/Al
using a metalizing gun. The coating will last longer than galvanizing, and longer than a new anchor.
Regalvanizing uses a hot dip process that can melt the lead out of some anchors, not so with Metalizing now referred to as Thermal Spray.
Thermal Spray doesn't require minimum weight as most galvanizing shops do.
Chuck
Both of these recent educational posts are on topic. These new posts are the ones you seem to object to.
I accept that there may even be rules requiring new posts, but I fail to see the logic of spreading the useful information all over the place. I applaud the people who put the pricing and alternatives in a thread about re-galvanizing anchors and chain. Very helpful.
skygazer is offline
galvanized vs stainless YACHTS33 Gear & Maintenance 4 10-19-2007 03:03 AM
Stainless or Galvanized? capecodphyllis Gear & Maintenance 18 12-12-2006 03:57 AM
Anchor Set Up KAYAKDAN Gear & Maintenance 18 03-19-2006 03:37 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 04:46 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 09:00 PM
