Old 06-26-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Yamaha 2.5 4 stroke issues
My 2004 Yamaha 2.5 4 stroke is having what I think are carb issues
(lo carb diet?)
After doing spring commisioning and testing last spring I loaned it to a friend last year as a kicker for his small sail boat and ultimately it got laid up without being used (read gas left in tank and carb for a year while laying in his basement).
I've drained the tank of the gummy gas, rinsed it with clean and refilled the tank. Drained all lines, drained the 'bowl' (really a tube) and cleaned it all out with carb cleaner and reinstalled the carb (and gasket).
The motor will start and run with starter fluid sprayed into the air intake, and will occasionally pop with no starter fluid - but will not continue running once you stop spraying starter fluid. I've worn deep blisters on the index fingers of both hands pulling the starter and beginning to give up.
It seems like it's a fuel flow problem. Yes the fuel shut off was open (and turned to closed as well just to make sure I did not reinstall it back wards).
I also tried to start it with the vent to the tank both closed, and open (normal).
I took it back apart and blew into the fuel intake housing (where the gas tube goes into the throttle body) and no air flow was apparent, but I'm not sure if that is a good measurement. In either case the results were the same.
Right now the entire carb is sitting in a can of gum-out soaking. I really don't want to have to dissemble the entire carb as I don't have a rebuild kit and don't know the adjustments etc.. I'd have to make.
Anyone got any tips, hints, tricks or tales?
(besides not loaning equipment to friends
Old 06-26-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Take it to a repair shop, send your friend the bill. I have been there and you pull so many times that you end up crawling away rather then walking. Let go the stress, take it to be repaired.
S/V Scheherazade
Old 06-26-2008
theartfuldodger's Avatar
theartfuldodger is an unknown quantity at this point
Send a message via Skype™ to theartfuldodger
I have the same engine and went throught the same situation to find the vent in the fuel tank plugged, found this by providing a separate fuel source.
The Artful Dodger II
NFLD and Labrador
33 Morgan O/I
Old 06-26-2008
chucklesR's Avatar
Free, motor's worth 500, the shop costs 95 a hour, 3 hour minimum and as I said it's a friend - and he's standing right next to me as I work on it (it's sitting on a rack at his house now). Repair shop is not a option.
Art, I took the top off the tank just to check that, didn't help.
Old 06-26-2008
arbarnhart's Avatar
arbarnhart is on a distinguished road
A couple of dollars spent on fuel lines (you didn't mention whether or not you replace them) would be a good idea. Before you cut and install the new fuel line, attach it to the carb still too long and filled with gas (be creative but careful) with the open end held up high. See if it will crank and run the gas out of the line. If it will, then the carb is ok.
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
Old 06-26-2008
chucklesR's Avatar
I did not replace the fuel lines because when I detached them from the carb the fuel ran just fine all over my index fingers newly blistered and open sores. Fuel appears to run just f%&ing fine up to the brass tube that goes into the throttle body.
Old 06-26-2008
Cruisingdad's Avatar
Best Looking Moderator
Ahhh... welcome to the wonderful world of 4 strokes. I had two strokes for a long time and hardly ever had issues. Is it just me, Chuckles, or do you feel like they suddenly decided one day to switch over to 4 strokes (and take away the 2's) without actually trying to start one at the factory?????
I have a Merc 6 that runs really well after every $300 tune up bill, until the 90 warranty is off and it is right back to CHug... spit... chug... die unless you have 1000 rpms on it.
Is your engine made by Tihatsu? I think it is.
At any rate, this will not help your current woes, but I have found the ONLY way to prolong (key word P-R-O-L-O-N-G) the time between shop visits is to run it dry everytime you go to put her up. Pull the fuel line and just let her go until she is dead (and I mean that in every possible sense). I also run a fuel cleaner in her. THis has helped considerably. If you do not run her dry each time, you will be faced with the same problem (exception is when you run her everyday. When we were Liveaboards, this was never a problem. Go figure??).
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 06-26-2008
Junior Birdman
Iflyka200s is on a distinguished road
Chuckles....
More bad news I'm afraid.......
I have a 2005 Yamaha 4hp 4 Stroke.... guy owed me money... Anyway mine sat for a year w/gas and it got so gummed up even though I took the carb off and cleaned it in the whoptie sonic aircraft parts cleaner at work....
I still had to rebuild it...it was just too gummed up even for the nuclear cleaner's I used on it.
Also sitting killed my fuel pump too...
Best of luck,
Tim
1988 Seaward Fox
no name yet (it's in pieces!)
Coconut Grove, Florida
Old 06-26-2008
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
I had the same problem w my 3.5 Tuhatsu. Thought I'd cleaned it out and it ran rough and only w the choke on. A friend suggested the needle valve was clogged so I added some carb cleaner to the gas. I put it in a barrel and got it running like a kitten in about 10 minutes.
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Old 06-26-2008
Freesail99's Avatar
I use to use carb clearner so much, a friend of mine, called it tune up in a can.
S/V Scheherazade
Nissan / Tohatsu 6h 4 stroke audeojude Gear & Maintenance 205 6 Days Ago 09:01 PM
Outboard Motor Bracket "not for use with 4 stroke engines" petertribo Gear & Maintenance 6 07-28-2007 07:49 AM
2 stroke vrs 4 stroke outboards dsbentley Gear & Maintenance 11 07-10-2006 11:27 PM
Yamaha 4 stroke Ozsail Gear & Maintenance 1 06-05-2002 01:32 AM
