06-27-2008
Swansea, MA
Split coupling! You had me totally scared. I pictured four bolts radial to the shaft, so that the the ends of the bolts were pushing on the shaft.
If if were my boat I would have positive locking as well. What I did on mine when I replaced the shaft, coupling and Packing to a PSS system was:
I had a brass key way machined into shaft,
two locking bolts radially installed 90 degrees from the key in which I counterbored 3/8 deep into the shaft for the bolts to bottom out into.
This way if the key sheared or got loose and fell out, or the press fit between the coupler failed, or the bolts broke the wire and starting backing out that the bolts would stop any movement aft of the shaft.
Saftey factor 5.
I don't know the specifications for the split coupling you have so I can not say for certain what it rated for. But I assume that you did let the shop know the HP, and gear reduction of the power plant? So that they matched it properly.
Split is definately easer to install, I would not use one though. Since the clamping force of the bolts is going to take the whole load of the motor.
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
