06-27-2008
The mechanical properties of the adhesive aren't really the same as epoxy. Epoxy tends to dry to a very hard solid form. Most of the polyurethane adhesives tend to stay fairly elastic and flexible. You're trying to stiffen the cockpit sole, and a flexible adhesive isn't really going to do it.
BTW, Liquid Nails tends to foam a bit and take up space, but the material really isn't all that strong if it isn't in direct contact with a surface from my experience working on my sister-in-law's condo.
What you need to do is cut the laminate, dig out all of the bad core material, lay in new core material—either end-grain balsa, Airex or Divinylcell foam—bedding it in a thin layer of thickened epoxy to adhere it to the lower skin, and then glass over it, creating a new cored laminate to re-create what was there originally.
