06-27-2008
If the stuffing box is causing enough resistance to stop the prop spinning... you've got a serious problem.
Just curious, is this boat new to you or have you owned it a while? If the boat is new to you, I would HIGHLY RECOMMEND that you re-pack the stuffing box after inspecting the prop shaft for wear, scoring and other issues.
Originally Posted by rperret
SD
is there a correlation between tightness of stuffing box and whether the shaft spins when under sail (if tranny is in neutral).
strane thing happened during wed nite race before start - shut engine down - put gear in neutral - and was under main doing about 4.5kts under sail when all of a sudden the bloody shaft starts turning (note I have a martec folding prop). i placed it in gear in reverse and it stopped turning.
in the past 2 years this has never happened...
