Installing refrigerator - Page 2 - SailNet Community
post #11 of 22 Old 07-01-2008
I bought one of the cheap $150 12 volt coolers. Its in the dumpster at the boat yard if any one wants it. I would feel bad trying to sell it. what a wast of money.
badsanta is offline
post #12 of 22 Old 07-01-2008
TRMN8R's Avatar
I guess I better 'kick my Koolatron' to the curb tonight.......................
Ericson 27
Buffalo NY
TRMN8R is offline
post #13 of 22 Old 07-02-2008 Thread Starter
Detachable member
wchevron's Avatar
pub911 you nailed it on the head. it would be nice to have a few cold ones sitting waiting for me. after all the responses i think i'm going to have to go with the marine fridge. now i know what to ask for christmas.
wchevron
s/v Time Flies
'78 C-30
wchevron is offline
post #14 of 22 Old 12-10-2012
Soverel 30 MKIII
karenmroberts's Avatar
Re: AC fridge
Originally Posted by ahab211 View Post
I've used an AC fridge and left frozen chemical ice packs in it when away from shore and a cheap inverter will work off your batteries in a pinch. For a hundred bucks it's a cheap fix.
Me, too! From one who can only afford old boats ... I've used Dorm frigs on two different boats and they never rusted. I'm sure if you submerged them in salt water they would but that's not likely and even if they did you're only out $100 bucks. I do not have the money for such luxuries. The only thing about dorm frigs is they need to have breathing room. They are not designed to have the backs enclosed so just be careful where they are stored. For a day sail, I just keep the door closed and never have a problem. Generally there are just drinks in the frig and nothing that will spoil over a day outing. Dual voltage frig means larger draw on house system and now upgrading battery banks, blah, blah, blah, the 'boat that Jack built'. Guess it comes down to what are you using the boat for and what's in your wallet???
karenmroberts is offline
post #15 of 22 Old 12-10-2012
Old enough to know better
Re: Installing refrigerator
I know there have been posts of people who tear apart a dorm fridge and put the guts into the ice box. Not the best solution but perhaps better than just bungee cording in a dorm cube fridge. By the way if you want to try this you have to make sure to get one with the coils on the back, not the ones with the smooth back. This way you keep the appearance up but get AC refrigeration. I think for many people who only day sail it is a good option.
miatapaul is offline
post #16 of 22 Old 12-10-2012
One of None
deniseO30's Avatar
Paul, most little dorm type fridges the "coil" that used to be on the back is now bonded to the outer aluminum skin of the box. then it's all foamed in place with the inner box. the outer skin will feel warm when it's running. Only the evaporator and compressor are really worth removing. I was going to do that to my boats ice box but went with a new unit that was on sale at Defender marine.
My last project!
deniseO30 is offline
post #17 of 22 Old 12-10-2012
SchockT's Avatar
It seems like a whole lot of hassle to go through if you are just day sailing or even just weekending! We get by just fine with a good old fashioned ice box! If I want cold beer waiting for me on the boat I store it in a locker that is below the waterline against the hull so it is quite cool. Of course I drink good quality darker beers that don't have to be ice cold to taste good!
As much as it would be nice to have refrigeration on the boat, and I have the ability to install it myself, we always seem to find higher priority things to spend the money on when it comes to the boat!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #18 of 22 Old 12-10-2012
chef2sail's Avatar
Denise what did you wind up buying?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #19 of 22 Old 12-10-2012
Yea, that is why i mentioned it. It pretty much locks you into a Craig's list/Goodwill finds. I know one that I saw on line showed that he got the wrong kind originally and had to find one with coils on the back. I think that a proper system is better, but may well be out of many folks budget.
post #20 of 22 Old 12-10-2012
celenoglu's Avatar
front opening fridges are not good for marine use. The above comments are correct for them and you cannot open the door when sailing, all the goods inside will fall down.
celenoglu is offline
Installing an anchor windlass GoodOldBoat Good Old Boat 9 05-23-2015 05:53 PM
Installing an anchor windlass GoodOldBoat Good Old Boat 2 06-05-2013 10:10 PM
Installing Treadmaster Nonskid Sue & Larry Gear and Maintenance Articles 0 07-11-2004 08:00 PM
Installing Treadmaster Nonskid Sue & Larry Cruising Articles 0 07-11-2004 08:00 PM
Installing 12-Volt Refrigeration Sue & Larry Gear and Maintenance Articles 0 06-18-2002 08:00 PM
