Old 06-28-2008
landlockvasailor's Avatar
landlockvasailor is on a distinguished road
Salt and Fresh outboard for grandson sailboat
I need to have the capacity to have an outboard for both salt and fresh. Knowing that flush will be needed on salt, which one, Yammie, Merc, Nissan, or Honda, are more apt to have less problems. This is for a grandson so I would like to have an opinion as to which one is more bullet proof for a teenager, I am sure you understand what I mean.
Thanks
Tom
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 06-28-2008
Quickstep192 is on a distinguished road
My boat has a Honda for going on ten plus years now with very little problem. I'm on the Chesapeake so you could debate whether that's salt or fresh, but it's never been flushed. I'm sure I've just jinxed myself.
In everything I've read, the Yamahas get high praise as well. The decision point for me would be which had the best local support. My local Honda dealer closed their doors a while ago and now I've got no one to go to for repairs that I'm either unable or unwilling to do. Same for parts. Even when I can do a repair or maintenence myself, I can't get the parts locally so I have to get them by mail whuich elongates my repair time.
Old 06-28-2008
cabron99 is on a distinguished road
I have had a Merc 9.9 hp on my c27 for a couple of years. I'm sure the PO never flushed it, as soon after purchase, it quit squirting out the coolant. I'll save you most of the details that followed. The point being, using a standard "ear-muff" type flusher was not practical. That's why it never got flushed. Now I simply remove the engine cover, disconnect the rubber tube that transfers the coolant to the outside of the engine compartment, and slip on a properly sized tube, downsized from a water hose, with a shut of valve incorporated, and flush the system in reverse. Seems to work beautifully. Good luck. Pat O
Old 06-28-2008
TohatsuGuru's Avatar
Misanthrope
TohatsuGuru is on a distinguished road
They are all equally as good. The Honda is the eldest design of the bunch, but lacks the power of the Tohatsu/Nissan\Mercury.
Elvin
Solution One Maritime
Old 06-28-2008
75R20 is on a distinguished road
I have a Honda 7.5 that is 33 years old, and still starts on the very first pull. I put in a replacement set of points and plugs this year, and that is about it for maintenance with the exception of normal fluid changes. The points were original.
Kary
#49080
Old 06-29-2008
Banshi's Avatar
Banshi is on a distinguished road
I have a Honda 7.5 as well, bought used, cranks first or second pull everytime and purs like a kitten. There are some motors that are not meant to be put in salt water so do some research before you buy. I've owned a chrysler and evinrude in the past and really had no trouble with either. I think maintenance and proper use will give long life with most any of them.
1976 Chrysler 22 "CinJam"
Old 06-29-2008
Thanks to all for their input, it is appreciated
Fresh or Salt Water Taste Test NauticalFishwife Gear & Maintenance 4 06-03-2008 11:04 AM
Fresh Water Better Than Salt Water? zaldog Boat Review and Purchase Forum 12 04-04-2007 11:07 PM
Fresh water boat to salt water svs3 Boat Review and Purchase Forum 6 12-30-2006 12:41 PM
Fresh to Salt barefootsailing Gear & Maintenance 1 04-25-2003 05:50 PM
Moving from fresh to salt water thomsonjd Boat Review and Purchase Forum 5 12-12-2001 04:50 PM
