Shaft coupler woes - Page 2 - SailNet Community
post #11 of 25 Old 06-30-2008
it depends on how well machined the shaft and face are to begun with. If they're relatively true, should be able to sneak by without facing and fitting, but will probably end up with more wear and tear on the shaft in the long run.
Originally Posted by jr438234606 View Post
Is it possible to get a true fit, or at least an acceptably true fit, without having the coupler machined to the shaft? I realize that would be ideal, but it's not very practicle for me right now.
sailingdog is offline
post #12 of 25 Old 06-30-2008
Here is a link to help calculate the interference between shaft and coupling...
http://www.tribology-abc.com/calculators/e3_8.htm
It looks like a typical interference ratio... delta/d... is about 0.001. The units in the article are those silly metric things.
Anyway, a shaft of diameter 1.25" should have an interference delta of about a thousandth of the shaft diameter, or about 1.25 thousandths of an inch, or 1.25 thou" as it is written sometimes.
I am not familiar with the surface finish arguments there, but it looks very much like you have consider them also.
Still, it gives an idea of what the designers have to consider.
Rockter.
Rockter is offline
post #13 of 25 Old 07-01-2008
Hal...
I am shocked, stunned, and deeply hurt.
I want a full written apology, carved in 3" letters into a solid granite slab, 3 ft x 4 ft x 24 ft, sent to Scotland by 6 pm today, GMT.
I said 0.43 thou"..... and not 0.43" .......yeeeeaaaarrrrgggghhhhh
That is 0.43 thousandths of an inch, and not 0.43 inch.
Don't miss the thou" bit.
0.43 thou" is an interference fit and won't go in without force but 0.43" won't go in at all, at all.
Rockter.
Rockter is offline
post #14 of 25 Old 07-01-2008
There is one hour and 3 minutes left.
Rockter is offline
post #15 of 25 Old 07-01-2008
how close is close enough
Following the above instructions would most certainly ensure a proper fit of the coupling to the shaft. My boat has a large rusty chunk of something between the prop shaft and transmission. I know this because I am always saying to myself "that don't look right".
funsailthekeys is offline
post #16 of 25 Old 07-01-2008
Not anymore.
post #17 of 25 Old 07-01-2008
Saildog...
I guess I just have to sulk.
He though I meant an interference of 0.43" on a 1.25" shaft!!!!!
How do you write thou" anyway?
I mean what can you do but sulk?
I am sulking.
I have been sulking for 4.5 hours.
Rockter is offline
post #18 of 25 Old 07-01-2008
A sulking scotsman is not a pretty sight. You wrote it properly, he mis-read it.
Saildog...
I am sulking.
post #19 of 25 Old 07-01-2008
Maine Sail's Avatar
Hal...
Rockter.
Rock I read it correctly! I was just making a little light fun hence all the smilies and winkies and the lack of me including "thou" in my response... I thought the winkines would be a give away that I was merely ribbing ya...
Your carved granite apology slab is in the mail postage due on receipt..!!
______
-Maine Sail / CS-36T
Maine Sail is offline
post #20 of 25 Old 07-02-2008
Yea, but 0.43".
It's a disgrace!!!
Rockter is offline
Pacific Seacraft 34 ljbabin Gear & Maintenance 10 06-06-2009 11:18 AM
Shaft Coupler to Shaft attachment dhornsey Gear & Maintenance 20 06-30-2008 02:07 PM
Propeller shaft woes............. clayjay Gear & Maintenance 24 03-13-2008 08:17 PM
prop shaft coupler thurston Gear & Maintenance 2 12-31-2001 06:00 AM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
