06-29-2008
IMHO, you should probably use Epoxy, since if the polyester resin doesn't bond tightly to the existing glass, it will leave an area where water can collect and freeze, requiring you to do this all over again. Epoxy will bond far better than polyester resin.
THe finishing with Epoxy, barrier coat and fairing is a good idea.
