06-30-2008
Best Looking Moderator
Originally Posted by TRMN8R
Might want to insert a blocking diode which will prevent the panels from draining the batteries at night or depending on your electrical setup, preventing the alternator (motor) burning out the panels. Also, the hotter it gets the less effective solar panels are (interesting thought, isn't it?). Hope this helps!
True.
However, as SD said, it will slightly reduce the effectiveness of the panels. You need to weight the loss compared to the gain in making the decision to put in a diode. Note: Many panels (larger ones typically) come with them already installed. ANother option is to put a switch on the input side to manually flip off at night. I know that is how it "used" to be done by many long disctance cruisers.
I have a sneaky suspision you will be disapointed with the panels. Solar works, but you need a fairly nice (and generally rigid) array to maximize its potential. But I guess every little bit helps.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
