Blogs
User Name
Old 06-25-2002
evecircleM evecircleM is offline
evecircleM is on a distinguished road
leaving valves open
Just wondering if it is ok to leave the valves open at the dock. The valves for the galley and head are really hard to close. Does anyone know it it is safe to leave them open?
Old 06-25-2002
mikehoyt mikehoyt is offline
mikehoyt is on a distinguished road
leaving valves open
If no one is on board leave your boat unlocked as well. That way someone can close the valves if the boat starts to settle. If the boat is locked then close the valves.
I leave my valves open when I am aboard or gone for 1/2 hour. When I close up and leave the boat at the end of the weekend I close the valves.
If the valves are difficult to close because they are stiff, etc... you might consider replacing them.
A boat sank at the finger pier in our marina because his head valves were left open. It was a C&C Redwing 30 which has the head located below the waterline.
Regards,
mike
Old 06-25-2002
joshuaheard joshuaheard is offline
joshuaheard is on a distinguished road
leaving valves open
Close the thru-hull valves when you leave the boat for an extended period. I close mine for overnight or longer. If the valves are stiff, rebuild them. There may be an article on this web site, or another sailing web site, on how to rebuild your thru-hulls. You will have to haul the boat out of the water so you may wait until your next bottom paint to do the project.
Sponsored Ad
Old 06-25-2002
tappers tappers is offline
tappers is on a distinguished road
leaving valves open
If your valves are really hard to open and close you need to overhaul them. I did mine last week. It didn''t take long - I was able to fix the problem between tides while tied uo to piles in the harbour.
Tappers
Old 06-27-2002
lgsailor52 lgsailor52 is offline
lgsailor52 is on a distinguished road
leaving valves open
Why gamble? The valves are there to protect your investment. If they are difficult to close, replace them.
Old 06-27-2002
hamiam hamiam is offline
hamiam is on a distinguished road
leaving valves open
Good seamanship dictates that you should close your SEACOCKS whenever you are not on the boat.
Old 06-27-2002
leaving valves open
Thanks so much for the info. Had a feeling you should shut them.
Old 06-27-2002
leaving valves open
Just make sure if you have an inboard engine that you open the raw water seacock before starting it. Good luck.
Display Modes
vB code is On
open ocean SMALL trimaran? jbarros Buying a Boat 4 08-21-2004 02:42 PM
Guilt of leaving kids behind slynn Living Aboard 7 03-13-2003 07:57 PM
Open ocean crew position wanted. dld Crew Wanted 0 05-31-2002 11:55 AM
Entering and leaving dock solo bderosa Learning to Sail 6 05-08-2002 11:45 AM
Open 50 delivery Great Lakes to east coast timkent Crew Wanted 1 10-17-2001 08:19 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
