Blogs
User Name
  #11 (permalink)
Old 07-01-2008
negrini negrini is offline
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
I did install same windlass on my boat some years ago. Although your idea to use the panel DOES work, it don't provide enough safety to isolate the entire system. It will work as a "convenient measure" to avoid accidental operation, but will not isolate the system in case a failure. So, with such arrangement, you should have the 70A braker also in a handy location for an emergency, and you'll need also to toggle it off when you leave your boat (if you wired directly to the engine batt). That just seems a double care to me, and could fool you when needed to cut the system. I decided to install the breaker just aside the panel on nav station, so I can reach a SINGLE measure to isolate the things.
Another observation, I did also run a switch on helm station, and found it very usefull when docking on anchor (mediterranean style). But, for many (and I mean many many many) times I had problems because I used it to drop and pull anchor in regular ways. Mostly times, my chain got clogged and I didn't not "hear" it, I kept pushing the switch and made things worse. Other times, I was pulling anchor and crashed it on my pulpit as I couldn't "hear" it reached the deck level. Since I could not educate myself for the proper usage of helm switch, avoiding dangerous use of it, I decided to have bow only ones, and trust more on visual than my ears.
Beneteau Oceanis 43
  #12 (permalink)
Old 07-01-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Negrini=
You need to read his OP more carefully, as he is planning on using the 70 Amp breaker as well.
- I wire the positive and negative leads to the contactor with the positive lead going through the 70A circuit breaker provided with the kit. This way the 70A breaker is protecting the current to the windlass.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
  #13 (permalink)
Old 07-01-2008
jbondy's Avatar
jbondy jbondy is offline
jbondy is on a distinguished road
What I'm getting from all of this is that since the 70A breaker would be ON at all times, a failure of the contactor could activate the windlass even when power to the switch circuit is off. To be extra safe, then, I should turn off the 70A breaker when not using the windlass, which negates the whole point. I was planning to wire the power to the 70A breaker to the switched side of my main battery switch, so that it would only be energized when I'm aboard (or forget to turn it off when I leave). So my question is: is the contactor a failure-prone device? Has anyone experienced or heard of a failure?
Joel
Pokey III
'78 Pearson 323
Bayside, NY
Be the pig!
Display Modes
vB code is On
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 3 02-10-2008 02:07 AM
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 1 08-26-2007 07:03 PM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 08:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 07:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
