Old 07-01-2008
DrB DrB is offline
DrB is on a distinguished road
Sunbrella Jib/Genny Sock Cover
I have a bunch jibs/genoas that came with the boat that do not have a sunbrella cover so they can't be stored on my roller fuller for extended periods. The sails are in good shape, so I'de like to use them, but don't want to pay $200 to $400/sail to have a sunbrealla cover bonded on.
I have heard of this gizmo where there is a sunbrealla tube that you can slide over the rolled headsail and raise with the spinnacker halyard to fully cover the sail and protect it from light.
I am interested to learn if any one has one or has experience with one and what are the pros/cons with them.
DrB
Old 07-01-2008
DrB-
Just because they don't have a sunbrella sacrificial sun strip on them, doesn't necessarily mean they're not protected. Some sails use a clear laminate film, usually Tedlar, to protect the sails from UV damage. I'd recommend you inspect them to see if that is the case.
As for the genny socks, they work quite well, and make especially good sense if you have several sails that you switch between that are unprotected, since one sock will work for multiple headsails. The main pro is that they protect the sail very well and also help prevent it from unfurling in heavy weather. The main con is that the sock has to be removed before you can unfurl the headsail and put back on after each use.
Old 07-01-2008
EO32's Avatar
EO32 is on a distinguished road
They also protect your genny from unrolling if you don't tie it well or the furling line comes undone. Don't ask, but it can happen. It's not funny when you come back to the boat and your genny is flapping around.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 07-01-2008
TejasSailer is on a distinguished road
We have a genoa cover that has a full length zipper and is pulled up with a spinnaker halyard. We're happy with it. Our sail maker lined it with with some kind of slippery fabric so it slides easily. I'd have to ask him the name of the fabric.
Old 07-01-2008
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Those are ok, but will cost you same or even more, anyway. Unless you have several headsails, like SD says, it's not worth it for the work !
Nave Rara
Beneteau Oceanis 43
C-270 Main Sail zippered cover w/ lazy jacks, "Lazy Bag", "Quick Cover" Installation randy22556 Gear & Maintenance 0 02-27-2007 05:02 PM
Boat cover fosterm General Discussion (sailing related) 1 12-06-2006 09:09 PM
Refining Your Downwind Sails Brian Hancock Gear and Maintenance Articles 0 04-06-2004 08:00 PM
Mainsail cover davejean General Discussion (sailing related) 2 11-04-2003 07:19 AM
UV Sock Cover Don Casey Gear and Maintenance Articles 0 01-28-2001 07:00 PM
