07-02-2008
Senior Mumble
Securing Wires
To install the windlass, I'm running 4ga wires from stem to stern. In may places, there are places to attach cable ties so the weight of the wires is well suspended. In several places, all there is are the bolts that attach the deck to the hull. I temporarily suspended the wires from these by wrapping a cable tie around the bolt and running another tie thru the first one, this second tie holding the wires. But I'm pretty certain that these will fall. Short of drilling thru the hull  , what's the proper way to secure ties in areas like these? I can glue a small block of wood to the hull and screw a cable tie to that. They sell small brackets for ties that I see stuck around other parts of the boat, but they're always supporting small wires. They have to be better secured that just the double-sided tape they put on the back of those things to support this kind of weight. There are panels I've removed to get to these parts of the boat. I could screw a small block of wood to the liner to support a tie. What has worked for others?
TIA
