07-02-2008
Motor Mount Replacement?
All,
Alas, the forward starboard motor mount under my Volvo TAMD31 has badly compressed...maybe an inch lower than the others. While the motor sits stable on mounts at all RPMs, I'm afraid the compressed mount has thrown the engine out of alignment, albeit modestly.
There's an automotive CV joint between the transmission and the prop shaft, which I suspect is bearing the strain. The cutlass bearing was recently replaced.
My yard quoted 70 hours of labor to a) remove the transmission; b) replace all four motor mounts; c) install an aquadrive.
There's excellent clearance under the oil sump for a small jack - and I'm wondering whether anyone has experience replacing motor mounts, and whether this is job that can be tackled by a) loosening all four mounts b) removing the CV joint and c) jacking the engine up by the sump (with a proper board as a brace) and then d) swapping out the defective rubber mount. I've run the boat for years with CV joint successfully and wondering what an aquadrive would provide that a CV joint would not, and whether this was a change worth making (I'm thinking of carrying a back up CV as a spare...)
Hate to part with that many $$ on a job that might be done more simply by myself...
Anyone dealt with this?
