Ignition Problem.. - Page 2 - SailNet Community
post #11 of 14 Old 07-03-2008
It takes three things for a engine to run........do you have them?
1. fuel......... proper mixture of air and fuel. You need to verify.
2. Compression.....you probably have this one because the motor ran, but a quick compression test will confirm. Bad timing chain ? how many hours on the engine ?
3. SPARK..........your symptoms suggest this but you need to verify this before anyone can help you.
Current flow will cause the voltage drop that you are seeing. It's normal to see lower voltage while cranking, and then higher voltage with the key in the on position, and the rising voltage is normal as the battery recovers after a high amp load such as cranking will cause.
Re-read my first post and go from there after verifing these things..
My bet is this.......The "box" has failed and is not breaking the circuit to the coil to trigger the high voltage spark. This will cause the coil to heat up excessively and then go bad also. Feel the electrical parts on the motor and isolate the items that get hot.
just my $ .02 worth of fuel and we know how far that will get you.
Kary
#49080
75R20 is offline
post #12 of 14 Old 07-03-2008 Thread Starter
75R20:
Short of a wiring schematic I'm not really sure how to trace it any farther than the big wiring harness that plugs into the engine. I ran it straight from that wiring harness to the ignition, and nothing changed. I also found a purple wire going into the alternator, but as I said in last post (un)plugging that had no effect.
Also, the engine was running fine until fuses started blowing so I am thinking the electrical problem should probably take priority...
The engine was just rebuilt last year, it worked all season. Then we parked it
for winter and some water got into the engine compartment, ruining the starter and the blower. Those got replaced last week, and now here we are.
kyoufu is offline
post #13 of 14 Old 07-03-2008
can sea-rays be far behind?
(jus' sayin')
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #14 of 14 Old 08-04-2008
Did you end up figuring this out?
I'm having the same exact issue. Could definitely use a tip on this one if you were able to fix it.
IfImHereImNotHavingFun is offline
Yanmar Starter dave6330 Gear & Maintenance 21 12-18-2015 05:52 PM
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 14 04-10-2013 08:46 PM
3GM: Engaging the starter idiosycrasies welshwind Gear & Maintenance 15 09-04-2008 06:08 PM
Ignition switch stuck in on position. padean Gear & Maintenance 15 09-24-2007 10:40 PM
