Old 07-03-2008
montenido's Avatar
montenido is on a distinguished road
Lost My Steering Today
Hi all. Went out on Sundance for the third time (gone almost 2 weeks fighting wildfires). Again no wind. I'm not sure what 's up. Anyway, my son was at the helm when he told me that the boat didn't "feel right". When I checked it out, the steering wheel had indeed become disconnected from the rudder. Luckily, I knew right where my emergency tiller was and installed it. So instead of struggling for control in no wind, we struggled for control under power. Made it in without any further adventures and left it in the slip. When I had it surveyed recently, the surveyor looked at the steering mechanism and thought it looked okay. Is it possible that the cable just slipped on one end? Has anybody had to replace a steering cable before? I know that I can do it, I just don't know if I can do it in less than 100 hours. This is a 1981 Catalina 30. Any tips or advice will be greatly appreciated.
Thanks in advance, montenido
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
  #2
Old 07-04-2008
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Usually an easy and dirty task, resulting on a regained steering and some cut/puncture on your fingers . But check where it failed: cable ? cable conectons ? quadrant ? chain to cable joint ? chain ? key at wheel shaft ? well, that could not be that easy, but the more you invest on it, more you know your boat .... although at some "non-sailing time" price.
Nave Rara
Beneteau Oceanis 43
  #3
Old 07-04-2008
Rockter will become famous soon enough
Mon...
Can you post a picture or two?
Failed steering is a heart-stopper.
Cable steering lets you fit an emergency tiller. Worm gear steering (mine), really is not so co-operative.
  #4
Old 07-04-2008
Hydraulic steering is pretty bad too.
Originally Posted by Rockter View Post
Mon...
  #5
Old 07-04-2008
hphoen's Avatar
"Nevis Nice"
hphoen is on a distinguished road
That happened to me once while sailing on a friend's boat. We were 250 nm SW of Bermuda, headed for Virgin Gorda, in a gale.
In that case, a shackle joining the cable and chain came unscrewed. Turns out it hadn't been moused by a contractor who had replaced the cable. But you really need to stick your head into the tight spaces and trace the steering gear from wheel to rudder post to figure out what happened.
Hud
s/y The Belle of Virginia
Island Packet 380 (now sold)
Nevis, West Indies
  #6
Old 07-04-2008
cnc33voodoo's Avatar
cap'n chronic
cnc33voodoo is on a distinguished road
fairly easy job.i converted my boat from tiller to edson steering in an afternoon.
on your boat it should be a cable system.
chances are the cable came loose or broke from corrosion.
not a bad idea to replace the cables if they are original.
c&c 33 tall rig
  #7
Old 07-04-2008
knothead's Avatar
Heck, they'd only be 27 years old. Aren't they good for life?
"wikijar"
  #8
Old 07-04-2008
montenido's Avatar
Thanks for the input so far. I will post some pics when I get a look at it. Might be several days before I can get down there. Would an engaged auto-pilot cause any trouble like this? It might have been activated while we manually steered.
Thanks, montenido
Channel Islands, CA
Mark Twain
  #9
Old 07-04-2008
Omatako's Avatar
Omatako will become famous soon enough
Depends on the auto pilot. Mine (Raymarine ST6001) has it's own tiller arm on the rudder pintle on which the ram works. With such a setup it's actually easy to "drive" the boat on the auto pilot controller.
Ordinarily though, if the AP is causing an issue it will be to lock up the steering rather than set it free.
We came through a force 10 storm uneventfully and the next day in total calm the steering went totally limp. My heart stopped at the prospect of that happening in 50 knots and a 9 meter following sea.
The cable end on the quadrant had come loose due to the PO not locking the lock nuts. We now have two nyloks back to back against each other!!
To respond to the original question - there are many variations to steering setups so I reckon the only useful answers will come from someone with the same vessel.
FWIW
Andre
  #10
Old 07-04-2008
camaraderie's Avatar
moderate?
"The steering system is quadrant with cables which allows it to be tuned as the boat ages."
If you haven't done any tuning at the quadrant...check there first...chances are the problem will be right there and obvious.
You may post attachments
You may edit your posts
Steering System Spring Checkup Tom Wood Her Sailnet Articles 0 04-26-2004 08:00 PM
Checking the Wheel Steering System Will Keene Gear and Maintenance Articles 0 07-31-2002 08:00 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
SEO by vBSEO 3.6.1
