07-04-2008
i don't think they make a standard hole saw in that diameter.
Originally Posted by Quickstep192
I would use a hole saw like the one shown here . Run it backward at first to get started; that will prevent it from digging in. New hole saws are very sharp and the sharp teeth can dig in, grabbing the material and either chip it badly, twist the heck out of your wrist or both. If you can reach the underside, go halfway through from the top and finish it off from the underside. That will help prevent it from chipping out. If your deck is cored, follow the sage advice above. In fact, if it were me and the deck was cored, I'd think real hard about how much I wanted that vent.
