07-08-2008
Jack up the stern by lowering the trailer tongue as low as it will go. Block the back of the boat up. Then jack up the bow by raising the trailer tongue as high as you need to. If you've got a long enough, strong enough beam, you can block it up under the bow and then pull the trailer out. Alternatively, you block up the bow with a stack of blocks, pull the trailer forward until a trailer cross-beam runs up to the blocks, then build a block stack behind the trailer cross-beam, transfer the load from the front blocks to the back blocks, take down the front blocks, pull the trailer forward again, build up the front block stack again, etc... Reverse the process to get the trailer back under the boat once you've done the work you need to do.
I've done it with a San Juan 21...
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , a new voice for ocean conservation
