07-06-2008
Also, the 12.8 Volts you're seeing is surface charge on the plates, and not the real voltage of the plates. If you would leave the batteries sitting for a day with no load and no charge on them, you'd see that the actual voltage of the battery, when fully charged, was more like 12.6-12.7 volts, and that the drop isn't a great as you're thinking.
BTW, SEMIJim is being optimistic about the 3 amp-hours supplied by the alternator. If your batteries are nearly fully charged, they may not even accept that much charging from the alternator, as the charge acceptance rate drops as the batteries approach being fully charged. If the batteries were at 50% charge, they'd probably take in the 3 amp hours he mentions, but if you're just leaving the dock and they've been charged the whole time and at full..... you're probably effectively getting less than an amp-hour or two from the alternator during half-hour of motoring.
