Bow thruster - theoretizing :) - Page 5 - SailNet Community
post #41 of 46 Old 07-09-2008 Thread Starter
Sea Slacker
Originally Posted by SVAuspicious View Post
Brak, where are you located? If you aren't too far away I'll sail or drive up and we can play and find something that works for you. I'm in the middle of the Chesapeake Bay.
Something does sound odd, but you have a good boat so we all should be able to help you get in and out of your slip without undue stress.
sail fast, dave
I am in Solomons, MD - if you are ever in the area, drop me a note and come by
brak is offline
post #42 of 46 Old 07-10-2008
Owner, Green Bay Packers
Originally Posted by brak View Post
BTW. another curious handling effect is that when I am moving under power at high speed (6-7 kts), turning to stbd is much harder than turning to port (and it means there is REALLY something that makes a difference, as usually hydraulic steering has 0 feedback). Under sail at the same speed - no such effect, both sides are equal. Must be something about how prop wash is hitting the rudder.
Sure sounds like a right hand screw. By "harder turning to stbd" I assume you mean not as effective turning moment. Any chance the screw is offset on that particular boat?
Wm. F. Buckley, Jr.
sailaway21 is offline
post #43 of 46 Old 07-10-2008
artbyjody's Avatar
What direction of the screwing is nearly not as important as the direction of the actual screw afterwards...resul;ts are the same I think..
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #44 of 46 Old 07-10-2008
Handsome devil
Stillraining's Avatar
Thats just plain screwy ...
Stillraining is offline
post #45 of 46 Old 07-10-2008 Thread Starter
Sea Slacker
"Harder turning" means I have to exert more effort when turning the wheel to stbd. - which means there is more force operating on the rudder, that I have to counteract. Much more - hydraulic usually lacks any feedback - when sailing it is absolutely not possible to tell what the rudder is doing other than by looking at the autopilot rudder indicator or waiting for the turn to occur, and check visually.
The prop is dead on center, comes right out of the middle of the rear portion of keel, sits in an aperture between the keel and the rudder.
Well, guess it's right hand all right. I wonder why the thing turns the wrong way, then. It's a mistery in its own right
brak is offline
post #46 of 46 Old 07-10-2008
Mermaid Hunter
SVAuspicious's Avatar
Dave,
I can understand your concern about hydrodynamics in a sailing vessel and the effects of a bow thruster tunnel on them but as someone who went to a school not too far from Webb, Kings Point, I'd be most interested in hearing about any merchant vessels with bow thruster doors, having never encountered a one in twenty years at sea. Grating to prevent lines and debri from being ingested yes, doors no.
You're going to make me blow rust off that part of my brain aren't you? My library is all in storage. I think the SL-7s all had doors. I think most of the ULCCs I came across did also. Certainly the MSC ships I worked on all did.
I might be through in late July or early August depending on wind and a business trip. I usually anchor up by the Holiday Inn so I can visit friends and walk to Woodburns.
SVAuspicious is offline
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 05:56 PM
Interesting Bow Thruster Topic from Tommy Solomon luckyjim Tartan 1 08-20-2007 12:35 AM
Bow thruster Artwerke Gear & Maintenance 2 06-15-2006 04:58 PM
bow thruster installation Myblueheaven Gear & Maintenance 1 09-10-2004 03:26 AM
The Basics of Doing the Bow Rich Bowen Racing Articles 0 03-20-2002 08:00 PM
