Cutlass bearing - SailNet Community
Blogs
Old 07-01-2002
lgsailor52 is on a distinguished road
Cutlass bearing
What are the symptoms of a failing cutlass bearing? I am gatting a metallic vibration at certain rpm''s , and also when I motor hard to port on my Catalina 30. No vibrations when the transmission is in neutral. Any input?
Old 07-01-2002
hamiam is on a distinguished road
Cutlass bearing
I replaced my cutlass bearing this year. Had similar symptoms. As you boat is in the water I guess I would suggest that you send a diver down and have him tug on the shaft. If there is play between the shaft and the cutlass bearing it probably needs to be replaced.
Old 07-01-2002
walt123 is on a distinguished road
Cutlass bearing
Another possible problem causing this is a worn shaft. I have had to replace shafts on older yachts. After a number of years SS shafts do wear and over the years can wear enough to need replacement. Measure the shaft when you change the bearing.
Old 07-01-2002
Jeff_H's Avatar
Super Moderator
Cutlass bearing
Another source can be misalignment of the propshaft as boats change shape over time and vibration dampers sag. It may also be a transmission bearing.
Regards,
Old 07-03-2002
gnorbury is on a distinguished road
Cutlass bearing
When my cutlass bearing wore out it was accompanied by significant vibrations (felt throughout the hull) at higher rpm ranges. In total there was probably 3/32" play between the shaft and bearing.
Fix it quickly! In my case the transmission burnt out while I was trying to hang on until the end of the season.
Graham
Old 07-04-2002
thomasstone is on a distinguished road
Cutlass bearing
I had exact same symptons. My cutlass was totally worn out, shaft was not true, and my prop was out of pitch. I took the whole lot to a prop shop and had prop re-pitched new cutlass pressed in and bought new shaft. Total cost $230.00.-thomas
Cutlass Bearing Replacement, 1985 Najad 343 kc_cmc Gear & Maintenance 2 12-07-2004 03:15 PM
How to Replace Cutlass Bearing? kcoffey General Discussion (sailing related) 1 12-05-2004 07:13 AM
Cutlass bearing alpeaks Gear & Maintenance 2 05-17-2004 02:10 AM
Mariner 39 Cutlass Bearing ABullard Gear & Maintenance 0 06-26-2003 08:57 AM
Cutlass Bearing parvenu Gear & Maintenance 6 04-15-2003 02:11 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
