01-12-2009
Xhawk-
You should probably really start a separate thread for your post, since you're pretty much off-topic. It would also help if you said what make/model fishfinder, transducer and boat you had—since, if you have the right transducer and boat, you can often get away with doing an in-hull installation. Of course, this is really not recommended if you have a triducer type transducer, which does speed, depth and temp. If all you want from it is the fish finding/depth sounder portion to work and you have a boat with a solid glass hull, you can probably do an oil-bath installation.
I'd also highly recommend you read the POST in my signature to help you get the most out of your time here. It has tips on searching sailnet, writing a good post, etc..
