07-07-2008
Split my dinghy open...
Inflatable Zodiac, don't exactly know the size, but don't think it's that important to the issue.
The tubes on either side are fine. The floor is fine. The problem is the floor split away from the tubes, where the floor was cemented to the tubes right in that crease. The splits are several feet (maybe as much as 3 feet) long along either side of the floor. Please understand, the floor itself is fine, the tubes themselves are fine, but the adhesive that holds the floor to the tubes has failed.
My plan was to inflate the thing in my garage, and stick the whole thing back together with 5200, then let it cure for a few days before deflating and transporting back to the boat.
First question: will that work?
Second question: will that still allow me to roll the thing up and stow it below?
Third question: I'd like to maybe glue some sort of big vinyl cross-piece to the outside of the boat, that's longer than the bottom itself, and sticks up to the sides of the boat to give it more holding power when someone jumps in it and strains the seams where I'm going to be 5200ing it back together. Is there a good place to buy a couple of long vinyl/whatever strips that I can glue onto the thing?
Not looking forward to buying a new dinghy. They're expensive, and this one appears to be fine except for the whole seams-splitting-open issue.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
